Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-27-2008, 04:44 PM
MAUSS MAUSS is offline
1979 Trans Am repaint opinions
I've been thinking that I need to freshen up my '79 Trans Am a bit. It needs a new trunk lid and I want to re-skin the doors anyway, so I might as well re-paint the whole car. It's the original Acrylic Lacquer (Mayan Red) and I'd like to keep the original color. The paint is still solid, but it's wearing thin. It lives outside year round and I was thinking about a single stage paint versus BC/CC. I'm looking for opinions. Thanks.
Old 03-27-2008, 05:47 PM
79C10's Avatar
79C10 79C10 is offline
Viva la Migra!!
re: 1979 Trans Am repaint opinions
Nice lookin' bird ,Mang.
It's like the polar opposite of the one in my avatar. It was White with a red sticker kit. As far as opinions go , I'd roll with the single stage. outside is hard on clear coat. Single stage can always be 'scuffed', cleaned and resprayed/touched up. clear coat is an art I never got the grasp of.
JMHO
Mike
Old 03-27-2008, 08:46 PM
Rag top bird Rag top bird is offline
I would go with clear coat it has a lot better UV protection then the single stage
Old 03-27-2008, 09:15 PM
RODDER18's Avatar
RODDER18 RODDER18 is offline
Single stage is ok for solid colors because it can be wet sanded and buffed. If it is a metalic color you can't wet sand it if it is done in single stage. Color sanding makes any paint job look better as it can remove surface defects such as runs, sags and dirt. If it a solid color I would use single stage urethane paint.
Old 03-28-2008, 04:30 AM
BTW, it is non-metallic right now. That probably explains why the original paint has lasted for so long.
Old 03-28-2008, 05:38 AM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
not to mention that a metallic is ALOT easier to spray in BC/CC.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1979 Trans Am repaint opinions"
327 '89 Trans Am GTA suggestions 3rdGenFreak Engine 2 06-29-2007 06:45 PM
th350 trans id excaliberprime Transmission - Rearend 9 03-17-2007 07:51 PM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 06:27 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 07:51 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 10:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
