Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-09-2008, 01:37 PM
jkingof9561's Avatar
jkingof9561 jkingof9561 is offline
350 heads or 305 heads...???
yes i have 350 heads (14102183) and 305 heads (14101081) and i wanted to know wich ones will run better both being ported a little bit and both having 1.94in and 1.6 in a 350 sbc bored 40 over, flat top piston with performer rpm intake and 280h comp cam...???any recomendations...
Old 05-09-2008, 03:45 PM
Thumper_Pumper's Avatar
Thumper_Pumper Thumper_Pumper is offline
muddin maniac
re: 350 heads or 305 heads...???
wat cc are both the heads
Old 05-09-2008, 03:56 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
JackOfAllTradesMasterOfNo ne
Both these come with 1.84" Intake & 1.50" Exhaust. The 1081 are 58cc Chambers. The 2183s I couldn't find may be 2193 but didn't show the cc. Should be pretty equal if they both have the same cc Chambers
http://www.chevymania.com/partsid/p...up=head&block=S
Old 05-09-2008, 04:00 PM
muddin maniac
is this your 400? if so i would go with the smallest cc heads for the more compresion too get the milage
Old 05-09-2008, 05:19 PM
da 350 heads are 1.94in and 1.5 with 64cc...stock...
da 305 are 1.84in and 1.5 with 58cc...stock...
wich ones are better to use350 heads or 305's for my setup??? (performer rpm intake 6,500,flat top piston,280h comp cam)
Old 05-09-2008, 06:18 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
I would use the 081's on your 350. If they are only ported a little bit, you can take that further to get more power. Lots of potential there but a full porting effort is required. Its all about air flow.
Old 05-10-2008, 12:30 AM
SSedan64's Avatar
Is this a drag only, daily driver, street/strip? I'd go with the heads with the larger valves unless you plan to put larger valves in the 305 heads.
Old 05-10-2008, 12:42 AM
i want dem for daily driving high performance street/strip...
Old 05-10-2008, 05:41 PM
SSedan64's Avatar
Your 350 64cc heads will be better for street/strip. Larger valves = more flow, The 58cc 305 heads on the larger 350 bore would be too much compression for pump gas. You want 9-9.5 CR to be able to use pump gas without detonation. Racing gas and Octane booster isn't cheap. Hell pump gas isn't either now.
Old 05-11-2008, 05:10 PM
F-BIRD'88's Avatar
Yada Yada Yada
The 350 heads he has to work with are the TBI swirl port heads. They have a flow restrictive swirl vane in the intake port that severely limits airflow and power.
The 081 heads once fitted with larger 350 sized valves will have a chamber volume in the low 60's. (slight chamber wall deshrouding is required to clear the larger valve radius) They will flow and perform very well once ported with the larger valves.
Of the two heads he has to work with, the 081's are by far the best choice.
The finished cr will not be excessive.
Old 05-11-2008, 06:19 PM
muddin maniac
id still take the 305s with 58cc cause on street racin ud come out of the hole like a rocket
Old 05-11-2008, 10:06 PM
SSedan64's Avatar
Didn't know those were the swirlports. There absolute junk. Friend of mine built a 90 Chevy van engine with those heads with flat tops. All it would do is detonate/rattle with any timing advance
Old 05-11-2008, 11:45 PM
well i been told by some one dat does porting and valve jobs dat da 350 tbi heads are better to use rather dan da 305s...why???cause da 350 heads flow more better once ported and have 1.94in valves wich are bigger dan da 305s 1.84in and dat da head gasgets will burn with time passing and after dat you will have a crossfire in wit pistons...so i no dat 305 heads work gud wit torque and throtle response but i want sumting for daily driving and to be running wit da best fuel economy i can have...but not worried about gas rite now...i just want to be running like a high to mid 11 with all of my setup and tranny...on a 3333lb car...
is there any hope with da 350 heads once fully customized...???
are they capable of making enough hp to be running a high-mid 11's once fully ported...???
thanks jerry
Old 05-11-2008, 11:53 PM
and da 350 heads i had them running once in almost da kind of setup without porting,cam and performer rpm intake...
i had da 350 tbi heads running with just performer intake,600cfm carb,stock chevy roller cam,no headers...and stock 700r4 tranny out of a van...and i was running like a low 14 quarter mile in a trans am...
but my question is...can they handle cam,performer rpm intake once fully ported with 1.94in and 1.5ex...???
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "350 heads or 305 heads...???"
Will Vortech heads from a 350 fit a 305? Ozz1967 Engine 26 01-04-2008 08:11 AM
305 tpi heads on 350 block need4superchevy Engine 4 08-09-2007 11:33 AM
350 sbc..305 heads?? learjet60 Engine 6 01-28-2005 07:28 PM
putting 305 heads on 350 low77ride Engine 8 01-08-2004 02:43 PM
Stock 350 with 305 truck heads? CrazyT Engine 2 08-01-2002 08:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
