Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 03-27-2008, 01:33 PM
windsor8 windsor8 is offline
AC and Power Steering Line Question ???
I need to fabricate some new power steering lines for my 48 Dodge , Caviler R & P to a Dodge PS pump. My question is: do ps lines and ac lines share the same crimping tool ?
Old 03-27-2008, 02:13 PM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
re: AC and Power Steering Line Question ???
anope....automotive AC lines are mostly -6 -8 and -10 with some large trucks using -12.
Power Steering lines are 3/8 (which is -6) BUT uses a different hose with a different wall thickness.
use to make em all the time, and have tried ac line (wont go up into the sleeves), and you have to get your crimps just so or they WILL blow apart.
however most shops that can fab AC lines can fab PS lines
Old 03-27-2008, 08:02 PM
Thanks for the information and reply.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "AC and Power Steering Line Question ???"
After market AC and power windows Countilaw Hotrodding Basics 14 07-30-2007 11:16 PM
427 or 454? jsdailey Engine 50 06-05-2005 09:12 PM
AC power in car? daimon1054 Electrical 10 07-31-2004 08:43 PM
Aftermarket Ford power steering pump suggestions? LanceB Engine 2 11-18-2003 03:32 PM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 05:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
