Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 03-26-2008, 07:12 PM
barnym17 barnym17 is offline
any body know?versalle brake bracket ?
Any one know where to get the bolt on caliper bracket for a 9 inch versaille rear disc setup? or what will interchange?
Old 03-28-2008, 08:02 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
 68NovaSS's barnstar
Wiki Edits: 3
re: any body know?versalle brake bracket ?
You might try these folks:
http://www.parts123.com/PartFrame.a...uickPerformance
I engineered my own using their basic design on a fabricated FAB-9 housing with big Torino ends, they work great, using Eldo calipers and their rotors. the rotors require a 5.710 hub flange and needs a 2.810 register, worked for me with Mark Williams Masterline axles.
Larry
Supercharging adds dignity to what would otherwise be a vulgar brawl
Old 03-28-2008, 08:44 AM
thanks for the info.
Old 03-28-2008, 09:04 AM
Irelands child's Avatar
Irelands child Irelands child is offline
10990
 Irelands child's barnstar
Wiki Edits: 2
The Granada/Versailles 9" sounds like a good idea - but parts for them have become almost impossible to find, new or used, OEM or aftermarket.
Dave W
Old 03-28-2008, 09:36 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 112
The piston size in a versaille caliper is somewhat large,(2.125"),and needs a large bore master cylinder and large brakes in the front to keep the system balanced.
I am in the process of sorting out a 65 mustang with versaille brakes in the back, and Baer dual piston 1.625 calipers in the front. It was impossible to get any presure built up with manual brakes and a 1" bore master, so we installed a hybroboost and and larger bore master.
We have yet to start the car, so I don't know for sure that things will work out.
Building a system around a brake set that is heavy, oversized, and somewhat obsolete is not a good way to start. The Mustang track racer guys used the versaille setups for many years, but it has fallen out of favor with them for the reasons stated above.
I'd suggest that you pick up a brake kit from ECI or speedway or adapt a explorer rear brake setup...it'll be much less headache in the long run, if you are starting from scratch now.
If you already have all of the brake parts, with the exception of the bearing retainers , I have a set that I will draw you the dimensions of, and you can fab them up from 3/8 plate. The actual caliper mount is going to be hard to fab.
The caliper mount is actually 2 pieces, the bearing retainer and a seperate caliper mount.
Later, mikey
BE different....ACT normal.
Old 03-29-2008, 04:10 AM
I've got the retainers the rear is complete exept for bolt on brackets, calipers and rotors, I was thinking of just doing what we do on stock cars. Weld on the speedway brackets and use jeep rotors with gm calipers.But to do this I will have to cut the mounting ears off the bearing retainers I beleive.Wanted to see if any bolt on brackets are out there first.
Old 03-29-2008, 07:52 AM
Wiki Edits: 112
I know the lincoln calipers that are available from my parts house are $$$$$, (IIRC they were over 100.00 each, rebuilt with a core charge)
So if you don't have the calipers, rotors and brackets already you may be money ahead to use the gm stuff.
BTW, if you do go looking for junkyard calipers, know that the town car calipers look very close the same, and will fit the bracket, except the piston is 2.5" .You can tell the difference externally though, the town car castings are smooth around the piston while the smaller Versaille castings have some square ribs cast in.
The town car calipers are WAY too big for use with a GM front caliper.
Later, mikey
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "any body know?versalle brake bracket ?"
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 10:29 AM
Free Body Diagrams BillyShope Suspension - Brakes - Steering 4 04-27-2007 04:40 AM
T bucket body demensions needed lowROLLERchevy Body - Exterior 3 03-21-2006 05:20 PM
Hotrodders Knowledge Base: Body - Exterior Jon Body - Exterior 0 11-26-2005 05:33 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 02:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
