Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-28-2008, 10:12 PM
Rosewy Rosewy is offline
can a 70s 350 mate up to a 90 gm trans?
My son has a 62 panel truck that he just put in a rebuilt motor in . Its a 350 out of a 72 c10. Now he asked me to ask you all if he can put a trans from a 90s pu in the old truck. So boys don't let me down, I know that you know the answer. Thanks
Rosie
Old 03-29-2008, 05:56 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
re: can a 70s 350 mate up to a 90 gm trans?
Rosie
manual or automatic trans?
the automatic will bolt up.
If you can't fix it with a hammer, you have an electrical problem.
Old 03-29-2008, 06:14 PM
66chevystepside's Avatar
66chevystepside 66chevystepside is offline
Yes as Crosley said if its an automatic. Any of the GM TH350, TH400, 700R4 will bolt up fine as long as the were from a pu with a 4.3 v6 or v8 - I believe the 2.8 v6 in early S10s is a different bellhousing and won't work. If it is a 700R4 you will need to hook up the TV cable properly and get a lockup kit for the overdrive to work.
Old 03-30-2008, 07:31 PM
70s 350 mated to a 90s trans.
Hi all,
tanks for the replys, I knew that you all wouldn't let me down. My kid has a granny 4 spd and is looking to put a newer 5 spd in a 62 panel one ton. I told him a auto probably would but not sure about a manual. He was concerned that GM changed the bell housing shape. He asks me because I was a test driver, that doen't mean I get to know about stuff like that. so I asked you. Thanks again.
Rosie
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "can a 70s 350 mate up to a 90 gm trans?"
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 08:17 PM
79 Trans Am engine swap to 350 JTedd Engine 1 05-10-2004 02:52 PM
350 trans. drives in any gear. racer56 Transmission - Rearend 6 12-02-2002 07:32 AM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 06:01 PM
Turbo 350 Trans Vacuum Signal? 54 Chevy Transmission - Rearend 2 07-22-2002 03:33 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
