Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 03-26-2008, 05:25 PM
sprecher48's Avatar
sprecher48 sprecher48 is offline
Oddo nut
 sprecher48's barnstar
Location: sunny south(maybe rainy,haven't looked outside today) florida
frame?
can anyone tell me of a frame I could use under my shoebox? Or has anyone had any experience in using another type of frame?
Old 03-26-2008, 05:44 PM
41Ford1 41Ford1 is offline
re: frame?
Well you could use a custom made frame by one of the aftermarket companies OR you could use an S10 pickup frame. Be prepared for alot of fabrication with most frame swaps. you will need to make everything from body mounts, radiator mounts, & motor mounts just to name a few. The best advice I can give is measure out everything and decide which will be close. I'm putting an S10 frame under my 41 ford and I've put a Ranger frame under a 48 ford pick up. They are alot of work and most people say don't do it for any number of reasons. I can tell you this, for my money this is the best option. Like I said measure, measure, measure and do some searches on the net.
Old 03-26-2008, 05:47 PM
sprecher48's Avatar
Oddo nut
re;frame
Well,since I have more time and ambition than money;I'll start measuring.
Old 03-26-2008, 06:50 PM
re: frame?
If you decide on an S10 frame shoot for a standard cab/extended bed (approx 117.9 inches) or a extended cab (121 inches). These two body styles provide the best platforms for shortening & lengthing depending on your needs. The S10 frames have a factory weld seam that can be ground down. Once this weld is ground the two halves slide together so you can lengthen or shorten from that point.
other tips:
-Look for an S10 extreme truck it is already lowered a few inches from the factory and has a quick ratio steering box.
-4.3L V6 trucks are said to have better sway bars but stiffer springs.
-4x4 truck rearends are stronger and longer if I remember right.
-Get the steering column, brake booster, master cyl. ,and brake pedal assembly if you desire.
-1st generation mustang gas tanks fit nicely where the spare tire would sit on the S10s.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "frame?"
Frame question Rufus_2 Suspension - Brakes - Steering 2 01-30-2007 08:52 AM
Notched frame, did I weaken it?? KernCountyKid Suspension - Brakes - Steering 48 12-31-2006 02:37 PM
Frame mods dusterbd Suspension - Brakes - Steering 5 11-05-2004 12:00 PM
Custom Frame (Long) Toyman Suspension - Brakes - Steering 1 08-29-2003 08:43 AM
repairing a cut up frame jniolon Suspension - Brakes - Steering 3 04-12-2002 05:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
