Hotrodders Bulletin Board
#1
GM turn signal wires
Hi
I'm installing a painless harness ,The plug for the TS has 8 wires, The end of the plug coming out of the column has 10 wires the 2 extra ones are lt green and tan .Anyone know what they are for,and do I have to connect them to anything? Thanks |
#2
gm wiring
Different year column's haf different number of wires.My brother bought the book HOW TO WIRE YOUR STREET ROD from sacramento model A parts and i got it when i bought his roadster. It lists Ford GM and Mopar Instructions, A good reference book to have. Dark green is ground... tan is ground ... green is right rear turn signal accordint to the book..The diagram shows 16 wires coming out of the column they used for the book (column key start switch)
#4
re: GM turn signal wires
See attached typical GM turnsignal wiring diagram.
vicrod |
Back to top |
Similar Threads for: "GM turn signal wires"
| how do i change out turn signal switch??? | hddave1 | Electrical | 4 | 02-27-2008 04:09 AM |
| Turn signal prolbem | dcpky | Electrical | 4 | 01-12-2008 08:39 PM |
| 50 ford rear turn signal help | Edbiosca | Electrical | 2 | 07-13-2006 06:45 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 02:00 AM |
| Turn Signal Short | Theresa Shank | Electrical | 11 | 05-17-2005 07:43 AM |
