Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-09-2008, 01:10 PM
tubbedz's Avatar
tubbedz tubbedz is offline
Ladder bar & suspension height
I'm helping a friend tub a '64 Nova. He has a CAChassisworks 2"x3", ladderbar, backhalf chassis welded onto his Nova. Per instructions, the lower tube on the ladder bar is set parallel to the ground. The car sits at ride height and the pinion angle is set. The front ladder bar mount is bolted to the top most bracket hole as there are only two holes in the front brackets. We have 29" tires on the car now, but out of curiosity, we installed my 33" tires. Now the rear of the car sits significantly higher. We have questions on lowering the suspension.
1) The rear coilovers are on adjustable rearend brackets with six holes to adjust up and down. It is centered now but we want to move the coilovers to the lowest holes to drop the rear of the car 2" - 3". Will this mess up the pinion angle and we need to readjust?
2) When the coilovers are are in the lowest holes, the lower bar on the ladder bar is not parallel to the ground and the front of the ladder bars now angle downward. Is this O.K. or should they remain parallel to the ground?
3) Also, with the coilovers in the lowest holes, the panhard bar is now not parallel with the rearend, but sits at an angle. Should we adjust the panhard to have it parallel?
Thanks
Old 05-09-2008, 02:01 PM
Mike H Mike H is offline
re: Ladder bar & suspension height
Yes you will need to reset pinion angle.
You are going to have to live with it unless you replace the front mount, The car should have been built with a 3 hole bracket with the ladder bar in the center hole and the axle centerline set at 16.5" at ride hight when it was built.
With the bar down in the front it is going to have some serious bite with a slick on it.
I hate panhard bars for that problem I would scrap the panhard for a track locator. if you build one with good brackets and 5/8" heims they will live on the street.
Hope this helps, Mike
Old 05-09-2008, 02:26 PM
tubbedz's Avatar
Thanks Mike
I thought so. I guess I have to break the bad news to him. He's stuck with 29" tires as I don't want to do any adjusting, welding or grinding just to fit taller 33" tires. I'm just feeling lazy.....
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Ladder bar & suspension height"
Ladder bar adjustments JSracing Suspension - Brakes - Steering 17 06-09-2005 02:27 PM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 10:05 AM
Ladder bar angle help brainsboy Engine 7 02-07-2004 10:21 AM
rear sway bar DeathByGreaser Transmission - Rearend 2 02-07-2003 01:25 PM
LADDER BAR BACKHALF Help Pro1972nova Transmission - Rearend 5 01-03-2003 05:06 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
