Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-28-2008, 10:10 PM
smokin63 smokin63 is offline
squish or quench on a supercharged engine
Been reading on quench , I am putting together my short block now and have not odered a head gasket as of yet until I decide on a thinkness . I am getting varying ideas depending on were I am reading . Kinda appears as though in a perfect world you would want 0 clearance between the piston and the head ,In the real world on the street it appears as though about .045 is good with a max at .060 . Any thoughts on the subject of quench on a street driven supercharged engine ?
Old 03-28-2008, 10:35 PM
RippinRon's Avatar
RippinRon RippinRon is offline
re: squish or quench on a supercharged engine
Zero deck clearance isn't necessary you can use a thinner gasket to achieve a good quench. You will want a max of .044" and some say as low as .035".
Old 03-28-2008, 11:46 PM
techinspector1 techinspector1 is offline
Senior Curmudgeon
 techinspector1's barnstar
Wiki Edits: 103
I use 0.035" to 0.040" for a tight fitting piston like cast or hypereutectic and 0.040" to 0.045" for a looser fitting forged piston because it has more room to rock on the pin. Blown or unblown wouldn't make any difference to me.
Old 03-30-2008, 08:46 PM
fiscus fiscus is offline
I've read about some serious blown engines using very wide quench heights so I know it is done. I don't know the details about the pros and cons though.
Old 03-31-2008, 03:47 AM
k-star k-star is online now
Jesus saves
quench
There is always alot of talk about perfect quench... 100's of internet experts will give you "ideal" numbers... The reality is very few people have the time or money to do all the R&D to prove out any of these theorys...
I was a big quench expert at one time, then i bought a big block chevy short block that was built by a person that is known for very fast, very dependable blower engines. The pistons were .100 down in the hole, and it had a .040 gasket on it. SOOOO, that is like .140 quench. That engine ran low 9's high eights with zero signs of "any" detonation. Oh yea that was on 100 octane fuel. Now i am no longer a quench expert...
Keith
K-Star Automotive
Performance Engines
The crash was easy: rehab is killing me-"John Force"
Old 03-31-2008, 12:09 PM
oldbogie oldbogie is offline
A blower motor is something of a different problem. Since the blower provides a lot of mixture turbulence, even when cruising along not providing much pressure, this reduces the need for the step to provide so much squish as needed in a "normally aspirated" motor.
For quench, while a blower motor can make good use of quench, compromises typically need to be made to get the compression ratio down to a livable number so quench steps tend to have wider spacing. To a large extent under competition loads where the blower is spun up and engine speed high, this isn't too much of a problem as again the blower's action is making plenty of turbulence and the high initial cylinder pressures from the overfill cause the flame front to move so quickly as to preclude the opportunity for detonation to occur ahead of the flame front.
The dangerous point with a blower motor is dumping a lot of throttle at low RPMS with a lot of load on the engine. This is a point where detonation can suddenly appear with disastrous consequences. Conditions for this would be a heavy car, with an undersized engine with a blower of some sort at low engine speeds in a high gear suddenly seeing a lot of throttle without a down shift. Another would be a heavy boat with a fixed pitched prop or one in low pitch in which the throttle is suddenly opened.
It's the old story "how can you have your pudding, when you haven't eaten your porridge."
Bogie
Old 03-31-2008, 01:38 PM
ap72 ap72 is offline
****** '72 Cutlass Supreme
Yea, a tight quench on any engine is a good thing, but sometimes you need to increase it to lower the static compression ratio- which is very important on blown engines. The best of both world would to be have high quench along with a reverse dome type of piston. Though even that may not be enough to get your static compression ratio low enough.
Old 03-31-2008, 04:41 PM
fatblock fatblock is offline
I agree with Bogie.The supercharger homegenizes the mix prior to induction.This effect offsets the need for tight squish like in a n/a engine.Quench and squish are the same and different,depending who you talk to.I always thought that squish shoved the a/f into the usable chamber vs quench that cooled far off a/f that could fire off and collide with the initial burn.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "squish or quench on a supercharged engine"
supercharged engine builds smokin63 Engine 1 02-18-2008 04:51 PM
the history of chevy v8's savman1 Engine 30 01-25-2008 12:02 PM
Trouble trying to start engine for the first time. Z-Money Pit Engine 3 07-21-2006 06:47 AM
Valve Lash adjustment hiball Engine 32 12-05-2005 08:28 PM
Need help with a timing issue... 383MontecarloSS Engine 30 01-01-2004 07:24 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
