Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-09-2008, 09:28 AM
mitchc mitchc is offline
1994 Chevy C1500 Vibration
Hey Guys and Gals..
This is not a Hot Rod question but one that is driving me nuts.. I have a 1994 Chevy C1500 ext cab pickup that I changed the Carrier Bearing a couple weeks ago and I now have this vibration that is driving me nuts. I had the tires balanced again and its still there. I checked the phasing of the drive shaft and it can only go back to gether one way, the front shaft is splined and keyed. The ujoints were in pretty good shape and had grease zerts and I greased everything when I put it back together..
Any thoughts??
thanks
Mitch
Old 05-09-2008, 10:36 AM
123pugsy's Avatar
123pugsy 123pugsy is offline
re: 1994 Chevy C1500 Vibration
Check to see if the hanger bearing is 90* to the driveshaft.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1994 Chevy C1500 Vibration"
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 206 07-17-2008 05:19 PM
56 chevy vibration at 55mph and up oldchevy1956 General Rodding Tech 5 07-22-2007 06:20 AM
91 model SS chevy C1500 Alternator Chris@whiterhino Electrical 2 06-01-2007 10:12 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 59 04-08-2007 10:25 PM
4:10's for Chevy C1500 RedLightedAgain Transmission - Rearend 0 07-10-2002 09:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
