Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-26-2008, 05:36 PM
bodydroppedsquare bodydroppedsquare is offline
What rearend gears
I have a four bolt main 350 bored over 40 flat top pistons 487x heads lunati 60102 cam with matching springs 1/6 ratio roller rockers edlebrock rpm performer intake cloyes double roller timing chain edelbrock 1406 carb stock exhaust manifolds backed by a turbo 350 transmission. Right now I'm thinking the truck has either 273s or 308s in the rear end what gears should I put in it to make the motor come alive but still be streetable???? The reason that I think it has 308s or 273s is because I jacked up the rearend and turned the tire a complete turn and the driveshaft spun 1 and a lil over half a turn... Is this right?
Old 03-26-2008, 07:41 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
re: What rearend gears
I would not go any higher than 3:73 or your highway mileage will be the pits.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "What rearend gears"
Want to change rearend gears in 57 Chevy... HELP!!! Drew's 57 Transmission - Rearend 7 02-21-2006 10:05 PM
rearend gears mustangchick Transmission - Rearend 6 06-08-2004 06:38 AM
Rearend Gears?? Doughboy1 Transmission - Rearend 3 12-21-2002 12:55 PM
3.27 rearend gears Butch358 Transmission - Rearend 3 05-19-2002 01:36 AM
3.73 rearend gears Butch358 Transmission - Rearend 2 05-17-2002 02:52 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
