My 1406, 625 CFM, has a black film on the top of it, and my friend next door said it was running rich. But I can't smell any gas in the
exhaust.
I've got the idle screws set from 1 1/2 turns, down to 1 turn each.
I'm still trying to get the timing worked out, but I would like to have the carb set right first.
Anything else you think I should do to it, let me know.
buy a holley or a demon. or i suppose you could try tuning what you have to tune you have to do much more than play with the screws, those are only for the idle circuit. you need to change the metering rods. I haven't messed with edelbrocks but im assuming they have primary jets? if so you need to go to smaller jets. I love how they say they are pre set and you bolt it on and go. If they do thats fine but if they dont its usually harder to adjust them than a holley. good luck.
From my experience it varies from carb to carb. The very first thing that you need to do is make sure the timing is correct. Then worry about the carb. Read the manual that came with the carb and figure out what jets and rods you should be running for your elevation and driving conditions. Read the manual CAREFULLY as it gives you lots of tips as to various things that might be happening, surging, flat spots etc., and how to adjust for them. Make sure that the carb is mounted properly with the right adapter if needed. You CAN NOT use an open bore manifold or adapter, you have to use the adapter with the 4 individual holes or an edelbrock intake or similar. Make sure that your vacume lines are connected correctly and not leaking, run a vacume test on it. You SHOULD run a heat insulating gasket on it as they tend to get VERY hot under normal driving. You actually need to play with it some to make it work as well as it can. I currently have 2 vehicles that I have them on. One a 1 ton Chevy fire vehicle that an edelbrock was put on and it runs great as is and my personal truck a half ton chevy that I'm still playing with after several weeks of off and on adjustments. You can also get "some" help from Edelbrock. The first tech I talked with was an IDIOT and his solution was that no vehicle with a carb would run in the conditions I drive and I should have bought something with EFI, however their Tech manager sent my e-mail to a different tech "PJ" who knows what he's talking about and really seems to care that I spent money on one of their products and was having problems with it. Good luck to ya.
where is it dirty at? what color is the smoke when you floor it at about 25 mph, I can ask around i have a few friends that have rebuilt edelbrocks. Its about as fun as rebuilding a q-jet. basically the same thing except square-bore. try to get light grey smoke when at wot. if its a black puff your rich on your secondaries.
From my experience it varies from carb to carb. The very first thing that you need to do is make sure the timing is correct. Then worry about the carb. Read the manual that came with the carb and figure out what jets and rods you should be running for your elevation and driving conditions. Read the manual CAREFULLY as it gives you lots of tips as to various things that might be happening, surging, flat spots etc., and how to adjust for them. Make sure that the carb is mounted properly with the right adapter if needed. You CAN NOT use an open bore manifold or adapter, you have to use the adapter with the 4 individual holes or an edelbrock intake or similar. Make sure that your vacume lines are connected correctly and not leaking, run a vacume test on it. You SHOULD run a heat insulating gasket on it as they tend to get VERY hot under normal driving. You actually need to play with it some to make it work as well as it can. I currently have 2 vehicles that I have them on. One a 1 ton Chevy fire vehicle that an edelbrock was put on and it runs great as is and my personal truck a half ton chevy that I'm still playing with after several weeks of off and on adjustments. You can also get "some" help from Edelbrock. The first tech I talked with was an IDIOT and his solution was that no vehicle with a carb would run in the conditions I drive and I should have bought something with EFI, however their Tech manager sent my e-mail to a different tech "PJ" who knows what he's talking about and really seems to care that I spent money on one of their products and was having problems iwth it. Good luck to ya.
Well you would be proud of me. I got the truck with the carb on it and with no manual. it came with one of those "open" adapters,
but I saw right away how bad it would flow with an open adapter,
so I got me a 4 holer.
Oh and there is a very small flat spot at mid range, but it is not a big problem to me.
And there is no black smoke from the pipes. and the exh does not smell rich at idle.
My manual is out in the truck and there is currently a couple of skunks on the front deck that I really don't want to offend to go get it LOL. I'll grab it in the AM and PM ya.
My old one used to get that film and my jets were dead on perfect,they will do that,its not a bad sign necessarily. If it runs good,just use a shot of carb cleaner once in awhile and go with it. I do like a Demon better though. Your dead spot is most likely a lean condition on the secondaries,up one size would probably cure it.
OK, you guys got me all hysterical now as I look at the new 1406 edelbrock (600 cfm) sitting here on the table, soon to go on my 350 SBC. Oh well, live and learn I suppose. I always thought that edelbrock made a fairly decent carb.
Edit/// Above link will not go to specific page. At the link above, select carburetors from the left hand column. Then select Edelprock Performer Carb Owners Manual. See Section 2.
They are good,the way they are made just shows the filth more. Don't sweat it,you will be happy with it,its only luck if you bolt a carb on and need not play with it to make it perfect,that goes for any carb,usually they are overjeted so they run good but use an unneeded amount of fuel from the box.
i just put a new edelbrock 600cfm on my 390, fired right up. after running the cam in, i too noticed a graphite colored film on the top of the carb....no smoke out the exhaust..... but i'm not too concerned with milage, and it runs like a raped ape. i'd have to say i'm happy so far, but i do intend to buy the calibration kit for it, cos oneday, i'll figure out wth to do to fine tune it. i think i might like to go a step lighter on the spring, and a tad less on the metering rod too.....
There is no set amount,I would start out about 3 and turn each one in slowly until it just starts to change the idle adversely,then come back out about 1/4 turn,its usually about 2 but the mixture needs are all going to be a little different,those only control your idle circuit.
My dad taught me long ago the exact same method of tuning carbs that rifraf described previous. It works on any carb of any car of any make and will at least make it driveable without any precision tools required. All by ear. Usually a short drive and a quick stop for a 1/8 turn here or a 1/8 turn there and I have saw many motors run troublefree.
If you want to tune the idle screws the best way as i have found is to use a vacume guage..
set your screws up to 1 1/2 turns,hook the vacume guage to manifold vacume then adjust them one at a time watch the vacume guage when the vacume peaks, back off the screw 1/4 turn, then move to the next screw..
This way always worked for me and set them up perfect.
The point is...the higher the vacuum, the better. That vacuum guage that you have in the cab, is for the purpose of getting better mileage. The higher you keep it while driving, the better the mileage. You will notice, when you mash the gas, it goes down to "0"
Thanks. I never knew what the point of it was, I just got it at a yard sale, and hooked it up.
I just looked at it, and it has vacuum in inches, 0-30. how do I make use of that guage?
Just turn the screws in and out to get the highest number without it varying,no less,no more,go back and forth a little to be sure and do it slowly so the motor has enough time to react. That vacuum gauge is also an awesome tool for timing your rig,I would take it over a light any day,you can use it for a lot of stuff,they are a good tool to have.
I heard somewhere that you can time it to max vaccuum and back off about 1 in mg, but when I tried this on my newly rebuild engine, my initial timing was way over 20 BTDC and I didn't think that was right.
Let us know because I am very curious.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
