Im almost positive it's where the whole front end of the body flips forward as a whole. Fenders, hood, grille, everything. Gassers used em a lot so they could work on the engine easier.
That refers to how hot rodders mount early ford front axles, especially on T-buckets and hot roadsters. They eliminate the front axle x-member and mount the spring to the frame with a little plate that is attached to the front of the frame. Thus the entire front suspension is hanging out in front of the car.
Funny how such a common term is lost in a generation. It was over 50 years ago that I helped a friend build a suicide. This was on, of all things, a tube frame sports car with Allard-style swing axles.
A center mount spring perch is the only place that the front end assm. is mounted solid, thus called a suicide mount.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
