327 any good
1K views 2 replies 3 participants last post by  BOBCRMAN@aol.com
I can get two 327 for 100$. They have beanseating out side they rusted the cylinder are rusted but not cracked the crank in on is rusted will it be ok .the other Is rusted cylinder but It has a oil pan on it . Is this a good deal The suffic code is HC and HCA . ARE they worth a 100 $.Will the crank's and block be polished and bored to be good. 70 Nova.
#2 ·
Thats kinna risky.You may have to break the pistobns toget them out.And depending on how pitted the bores are and if it been bored befor the blocks may be shot.
I'd ask if you can take one apart first so your sure you can get them unseized.If you got one good block and one good crank out of it it'll be worth it.
Are they both small journal engines??
