Hello!
I've been enjoying the information on this site for quite some time and have decided to present my ideas for my 400 SBC build up for the board's review and comments.
I currently have a 69' Corvette coupe with a ZZ3 small block, M-20 Muncie and 3.70 axle. This car has no power options- Manual steering, brakes etc.
Being an Oldsmobile big block guy since high school, the torque of the ZZ3 is not quite up to my expectations, so I have the following parts that an would like to put together and toss in the Vette:
1972 400 SBC, 4-bolt main
Bored .040 w/forged L2352F Speed Pro pistons (14cc Dish)
Stock crank and 5.565 rods
L-98 Aluminum heads that have been mildly cleaned up and gasket matched (58cc chambers, 1,94 intake, 1.50 exhaust, LT4 valve springs)
Elgin #E-901-P mechanical 'Duntov 30-30' cam- 254/254 dur @ .050, .485/.485 lift 114 LS.
ZZ4 dual plane aluminum intake with a Holley #4779 straightbore, double pumper carb
Stock distributor (recurved) with Pertronix II module and coil
Z-28 oil pan, windage tray and oil pump
With the pistons and heads, I figure around 10.6 compression-
This is strictly a street car that I'll drive in the summer for fun so valve adjustment etc is not an issue.
I wanted something that sounds cool at the light (hence the 30-30 cam) but gives me a little more kick than the bone stock ZZ3 when the light turns green.
Any comments on if all this will get me to where I am looking or do I have some glaring deficiencies that I need to address?
I realize the cam is a bit wild, but I REALLY love the sound. I figure they ran them in a 327, a 408 shouldn't be too awful?
If it's too hairy, I can always swap it out for something a little milder down the road.
Any clue what kind of power I can expect from this combination?
With a 3200 pound curb weight, 2.52 1st gear and 3.70 axle, will this give me enough low end torque?
Any comments suggestions would be greatly appreciated!
Thank you!
Elm.
Thank you!
Elm.
