I built a 415 stroker with Eagle crank, rods, Ross pistons in the lower end with a Mildon 7qt oil pan and pickup, high volume oil pump. Running Dart Pro1 heads with a Comp Cams solid mechanical cam and lifters and roller tip rockers. My problem is I have 25 to 35psi at idle hot, 50 to 60 psi crusing speed and when I get into the motor oil pressure climbs to 70psi then suddenly drops to 25psi or less at around 4000 to 4500 rpm and a soon as I let off the throttle oil pressure jumps back to 70psi. I have removed the motor replaced oil pump and pickup checked all bearing clearences old bearings look like new, replaced all bearings with new installed a widage tray bigger oil pan new pickup and pump and still have the same results. I do not uderstand why the oil pressure drops. I am running 8qts of oil with the filter and do not believe that all of that oil could go to the heads and puddle. I put 300 miles on the motor before tearing it apart and could not find anything wrong with it. Anyone have any ideas?
